RouterStats 4.3 application
Started by Pistol, Sep 03, 2008, 18:10:44
Pistol
Someone recommended this app, RouterStats, to track my line noise etc..  Its a great app thanks!
However i have noticed it, after an hour or two, starts using up almost all of one of my cores..., 40-50% of my 3Ghz E6600 cpu useage.. I have to shut it down  to get it to stop. Any ideas why this might happen? Cheers
also, when i shut it down in this case, it wont.. i have to hard end its process.
hmm, looking at the graph.. i see there was connection lost to my router.. wonder if it in that down time, went mental with its cpu usage..
B
I've only seen RS go mad once, and that was when it seemed to be unable to reach the router, and fell into a loop, producing the symptoms you describe. Drop John Owen a note, he's very responsive to bug reports and suggestions. :)
