Monitor.Vista enquiry
Started by David, Sep 05, 2008, 15:46:38
madasahatter
Looks like you got a real bargain there David -  :welldone: that man  :thumb:
Nice one, David. Worth waiting a day for. :) Still pleased?
David
Im over the moon with this monitor the colour is brilliant,sharp.I didnt expect such a transformation with just a monitor,at a loss to know why they have gone up in price and its not a little £30 is a lot when you think about it.
I would have ended up with the HP if I had not thought to ask for some help on here in choosing  :cheers: to you all  ;D
A good monitor is priceless, tbh, David - it's what you spend a lot of time actually using, the rest of the hardware is just driving the screen, really.  :thumb:
Odd that,because one of the sale headers is still at the old price until you click on it. I was tempted and probably will be when the price is right for me. Glad your pleased with it, all you need now is some surround sound speakers if you've not got some already.
David
Now now,are you related to Rik......I have just 2 and a subwoofer Steve.......I fancy that huey or whatever its called next  ;)
I got mine off flea bay, there is a new huey pro available in the US for £65 shipped. :)
David
David
 >:D >:D ;) Its ok wants a new kettle  :angel: NP  :laugh:
It would have to be firewire to heat the water, Steve. ;D
I highly recommend them, Paul. There is a Pro version, but it doesn't really add anything for the home user.
so this makes the monitor have the correct colours etc?
will it be useful for a wide gamut monitor?
Yes and yes. It puts up a series of colour targets on the screen and measures the output. From that, it can create an accurate profile which will allow 'screen to print' matching. It's not just colour, of course, it also sets up the grey scale - and the difference in that is usually very noticeable.
I think the pro monitors ambient light and adjusts accordingly????
have you bought from this site before rik?
No, I've never used them - I just Googled.
David
Quote from: vitriol on Sep 09, 2008, 09:29:49
I'm very surprised at this, I've ordered loads of components from Overclockers and every time it has been delivered on the day / specified time.  The delivery service is usually spot on.
Glad you got the monitor though David, take some pics please :)
I might be in the market for a new one soon
Have got a few pics as promised,is there any other way other than sizing them down as attatchments as on this machine at present have no photosuite at present ?
Upload them to your album or webspace, David?
David
Thanks Rik do I then just make a link to these ?
Quote from: Rik on Sep 10, 2008, 10:36:11
Do you have to leave it connected all the time or once its done its job can you disconnect it?
You can disconnect it, or leave it connected and it will adjust the screen for ambient light levels. As I try to control the ambient light level and quality, I tend to disconnect.
