Webspace Access
Started by jmcg, Nov 11, 2008, 17:02:32
jmcg
Could someone please tell me (or point to a guide) how to connect to and use my webspace? Thanks :)
You need an FTP client to upload files, JM, and after that it depends on what kind of thing you want to do with the space. As supplied, the free space is bald, ie no PHP, scripts etc. Essentially it can only handle simple web pages or host files. IDNet recommend Nvu for creating pages. If you're using Firefox, I recommend FireFTP as the client.
Welcome to the forum. :welc: :karma:
jmcg
Thanks for your reply... Where do I go to access my webspace (where do I find the address)? Thanks :)
Your Webspace settings are found here in your password protected account area
jmcg
...but you would need to log in first, to access that link.  ;)
:welc:
Quote from: Simon on Nov 11, 2008, 17:23:09
Ah yes, clicking the link takes you to the login, after logging in you need to click the link again for it to work
