2700 & DHCP
Started by Tacitus, Dec 10, 2008, 10:19:27
Quote from: Tacitus on Dec 12, 2008, 14:06:10
Brilliant!!  Thanks Steve, Alan & LesD.  I guess it always pays to RTFM.......
My main reason for wanting to specify the DNS servers is that I want to know what servers I am dealing with rather than leave it to others to decide.
You're best to define them in Windows, then, especially as the 2700 has a vulnerability surrounding DNS...
It's the stability as much as the speed that I notice, Tac. With a Netgear, my noise margin was all over the place and I rarely made more than a week without a re-sync. The 2700's been able to hold the line for 2 months.
Quote from: Sebby on Dec 12, 2008, 14:35:40
Actually I use a Mac as my main machine, though I do define the servers in the machine's network settings.
Quote from: Rik on Dec 12, 2008, 14:42:32
Strangely it reports higher figures than either the Zyxel or a Draytek both of which I've used in the past.  The Zyxels (AR7) were fairly stable albeit at a lower SNR and would 'sometimes' (not often) hold sync for a week or even 10 days if the weather was good.  The Draytek even with tweaking could just about manage a couple of days, three at best.
I got this msg here after a reboot this morning, so it looks as if BT have been messing about.  Wouldn't mind if they made some improvements but I've yet to see anything tangible....
Looks like exchange work, at a guess. :(
