I've just noticed
Started by Rik, Dec 30, 2008, 18:54:43
True - I'd be deprived and depraved. ;D
Good thinking, Seb. If I get away without being divorced, I'll have adequate backups. :)
What's really funny is that you know it's the sort of thing I would do. ;D
vitriol
Nothing like having a reputation, is there. :)
Quote from: Rik on Dec 31, 2008, 10:18:25
Thanks, Steve. I wonder if it's there for the Soundblaster card then?
Just noticed this thread Rik, I have this folder but I have a GTX 280 in my P6T the plug in provides things like powerdvd the ability to use just the GPU for video playback taking the load off the cpu, as you don't have Nvidia I would think its redundant and will not work without a Nvidia card of some sort, I would just leave it there, as has been said its not doing any harm, odd though  :dunno: unless another program added it as you say, my creative soundcard card did not, it was definitely from my Nvidia driver install only. The marvel of computer installs from OEM's  ;D
Thanks, Gary. I'll leave it quietly alone (or ZIP it if I'm feeling devilish ;D).
