Linux
Started by pup, Jan 29, 2009, 00:00:37
I won't bite. ;D
davej99
Quote from: Rik on Feb 02, 2009, 13:08:13
No plans for the time being - until I can't manage the stairs, anyway. ;)
Beware chairlifts!
Click and view the gif.
[attachment deleted by admin]
It looks fun! ;D
Quote from: davej99 on Feb 02, 2009, 19:01:02
Beware chairlifts!
:rofl: Wonderful. :karmic:
Colin Burns
Quote from: Sebby on Feb 02, 2009, 12:15:53
Now you've got me thinking about RAID 0+1, Rik. I only have 2 x 250GB hard drives, and they must be cheap as chips now. It's a shame a physically can't fit them in my case...
use the empty bay for the dvd rom drive unless you've filled it
Quote from: Rik on Feb 02, 2009, 12:47:40
I do the exact opposite, go for a big box with plenty of room for expansion. I have four HDs fitted, but could add another couple if needed.
yea I'm with you on the big case my problem is getting a power supply to power everything as I'm running
4 hard drives with a 1TB on the way soon
2 DVD ROM drives
and geforce 8800 oc2 over clocked that wants to be plugged in aswell
during the winter i miss the P4 i had as it used to heat my bedroom literlay
I reckon the computer is worth 1.5C of added heat. :)
Colin Burns
lol my P4 processor used to run in the 80c range  but since the Core 2 duo its like a icy fridge dannis the witness
I shall check with her. :)
Danni
It is in comparison. His old machine was warmer than my radiators.
The wonderful smell of roasting processors. :)
Then run on smoke you know, let it out and they don't work anymore :whistle:
That's where I've been going wrong all these years. ;D
esh
When I was working at CfA in Boston on an embedded electronics server, the project leader told me as I was sitting down in front of the board with serial number #1, "whatever you do, don't let the magic smoke out". It took me ages to figure out what he was on about.
 ;D
I've been trying to get it in...
You need to make it into a solid first
I have a mediocre second if that would do. ;)
