Zune & Itune
Started by Calum, Feb 02, 2009, 18:03:14
Calum
Ok simple question, is there a way of transferring a zune playlist .zpl file
into an itunes playlist or .m3u file, there seem to be plenty of ways out there to do the reverse process but i cant find any for people wanting to transfer there playlists from zune to itunes
Any help would be great. thanks  :)
After though! Who prefers zune and who prefers Itunes (software not devices, im not even sure if you can buy a zune in the uk)
Meribel. The heart of the Three Valleys!
I've only got iPods/iTunes, Calum. I've 'sort of' moved playlists from iTunes to WMP, but it was manual and clunky. As you say, the available solutions all seem to be the wrong way round for you. :(
Nice find, Steve.  :thumb:
Calum
Nice!
Ill see if it works and report back, cheers ;D
Calum
well it certainly worked.
not sure if its my files or not but its changed the name of every song i've imported. cheers anyway. i think the old fashioned way might be best
- while i was writing that it fixed itself, weird, thanks steve, exactly what i needed after that-
