Any Complaints? No!
Started by quandam, Feb 25, 2009, 18:34:18
quandam
How can I have any complaints?
Considering at this time of the night with Sky Connect (non LLU)  I would be experiencing speeds of minus 1mb, this is a dream.
Thanks IDNet for keeping the internet enjoyable.
Glad you are enjoying your new found stable connection, long may it last.
Good to know that you've achieved what you came back for, Quandam. My speed is always going to be limited by my line, but I know with IDNet that they will deliver the best it can handle at whatever time I want to use it. It's why most of us are here, I suspect. :)
quandam
Quote from: Glenn on Feb 25, 2009, 18:36:08
Yes, the word is 'enjoying'. It really makes a massive difference to how you use the internet.
Quote from: quandam on Feb 25, 2009, 18:34:18
It's a slightly optimistic test, but I reckon pretty close to your actual speed! We told you it was good here!
quandam
Quote from: Lance on Feb 25, 2009, 18:46:26
I do agree, but the very same tester showed the minus 1mb speeds when with Sky Connect. ::) every evening after 5pm. :dunno:
It doesn't get much better than that... ;D
