BT 2700 HGV Router Question
Started by quandam, Mar 01, 2009, 11:45:26
quandam
Quote from: Ted on Mar 02, 2009, 12:03:02
I'm sure there won't be a problem, mine was just too cheap. It would have cost around £6.50 1st class signed for, so he just played the "lost in the post" game, not that unusual when things sell too cheap on Ebay.
I actually said to Liz "bet you i never see that router" and i never did.
If you paid with Paypal and it doesn't turn up, you'll get your money back in full. Its up to the seller to prove it was delivered, not you to prove it wasn't.
Thanks for the info Ted.
I did pay by Paypal and thanks for that particular info as well.
quandam
Quote from: badpianoplayer on Mar 02, 2009, 12:12:56
Relax I followed the fantastic instructions from the saint like men of knowledge here and I did it.......enough said,honest you will breeze through it  :thumb:
Good news!
Alan's instructions are great - I followed them and had it setup in no time. :)
quandam
#28
Quote from: Sebby on Mar 02, 2009, 14:11:04
You Guys are building up my confidence. One daft  :blush: question before I get stuck into it (when it arrives), as it is new and unopened do I need to do a reset? :blush: :blush: :blush: as per instructions.
David
I think that you may have to just a pin into the factory reset will do it just in case  ;)
Ted
Quote from: quandam on Mar 02, 2009, 19:45:03
If the box has the security seal in place there is little point in resetting the hub. If the seal is broken but all the components are in sealed plastic bags, again there is little point in resetting the hub. If however, the seal is broken and the plastic bags are open then there is reason to suspect that the hub has been used and is therefore not "brand new". In this case i would do a reset of the hub, just to clear any settings that may be in place.
Always best to start with a clean slate ;D
Ted
We recommend the reset so that you know you are starting from a known base, it only takes a few seconds.
Feel free to leave the reset out if you want, but if you need help configuring it later, we will ask you to do one then  ;)
quandam
Quote from: kinmel on Mar 02, 2009, 21:32:03
Thanks Alan :thumb:
