My sync!!?! =O
Started by mrapoc, Mar 10, 2009, 17:17:17
mrapoc
Well
Just checked my router page..
from 8000kbps or whatever (8125 or something)
has now gone to
4160 kbps
As the chuckle brothers say... "Oh dear Oh dear Oh dear"
What's your noise margin, Sam?
mrapoc
24.0 dB down
21.0 dB up
Seems that's your problem, try re-booting the router.
Of course, the other question is what caused it in the first place!
It looks like a burst of noise caused a re-sync, but that noise source has now disappeared. Your normal sync should return following a reboot.
mrapoc
Back to normal now..
how weird =/
thanks  :thumb:
Must have been a burst of noise, Sam.
David
QuoteAs the chuckle brothers say... "Oh dear Oh dear Oh dear"
To you, to me, to you, to me   ;D
