exporting favourites
Started by sobranie, Mar 14, 2009, 20:30:34
Am familiar with the following procedure;
To import or export favorites
Open Internet Explorer.
Click the Add to Favorites button , and then click Import and Export.
Follow the instructions in the Import/Export Wizard.
By default, the Import/Export Wizard creates a standard HTML file named bookmark.htm and saves it in the My Documents folder. When you use the wizard to import your favorites, it will look for that file.
Anyone know a method to export en bloc as the above method will take forever and a day and doesn't accept a CTRL A command.
c:\documents and settings\your name\favourites copy the complete folder then paste into the new profile.
