Windows XP drive letter allocation
Started by Broadback, Mar 26, 2009, 09:11:11
Broadback
Is there any way of altering the drive letter that XP allocates a particular drive? My old m/c had the 1st internal drive as C the second as D, this one has the DVD as D and the second internal as G, confuses the hell out of me, not that that is difficult!  :blush:
Right click on My Computer, select Manage > Disk Management. Select the DVD drive, right click and select change drive letter. Change that to E or above. Then, select the second HD and change that to D. Job done. :)
JB
Control Panel - Administrative Tools - Computer Management - Disk Management
will allow you to swap your drive letters around.
Just be cautious in relabeling a disk with system files on it.
JB
Broadback
Thanks for your help, sorted now.  :thumb:
