2700 unlocked
Started by stevenrw, Mar 27, 2009, 15:25:13
stevenrw
I gave up on my previous 2700HGV because I couldn't get the wireless signal power as good as my Netgear. It seems that the hubs that are already "Unlocked" are the ones with the adjustable power output.
I did get an improvement on the line stats so I'm thinking of getting another one with the adjustable power option. I don't need the VoiP function in any case.
Two questions for you all:
SBC or SingTel - any difference/advatages/disadvantages between these two firmwares
and
Will having the hub with either of these firware changes compromise the line stats on a wired connection.
I primarily bought one because I'm a distance from the exchange and I wanted any improvement I could get in advance of the 21CN service. I thought the increased wireless range would be an added bonus but in the event it was it's downfall because it was unadjustable on the unit I bought. The desktop would be wired and HID's lappy will be on wireless. It's currently working but struggling a bit with the DG834 with 2 or 3 bars max. signal strength and bridges/access points/mains methods seem costly.
As I understand it  ;D the SBC firmware is for the older single SSID version .The singtel recovery firmware for the dual SSID  claims to be easier to set the wireless level but has a default downstream noise margin of 8 as opposed to the BT default of 6 which could result in a lower sync speed, so is not recommended for long lines.
The Dual SSID with firmware other than version 6 according to tripod can all be adjusted by using the opera browser and method 2 .Giving four levels of adjustment from 1-4 or 25mW to 100mW
The other drawback of the SBC version (which gave me a better sync speed than the dual SSID) is that it reboots every 12 days.
Yep, that's exactly what I experienced. I suppose that's not an issue if you have a perfect line, but when you have a poor line, it can be a nuisance.
