Primary/Secondary DNS settings
Started by MikeSh, Jun 19, 2009, 08:23:32
MikeSh
When I first joined IDNet some years ago I was given :-
Primary DNS Server: 212.69.36.3
Secondary DNS Server: 212.69.40.3
I noticed that the email from IDNet on completion of upgrade to ADSL2+ said :-
Primary DNS Server: 212.69.40.3
Secondary DNS Server: 212.69.36.3
I have ignored this reversal but can someone please confirm the original is the correct setting?
Does it really matter anyway?
Mike
On the letter I received in Dec 2005, it lists the DNS as
I'm not sure, but I don't think it would make too much difference. There may be a reason why the servers roles have been reversed, possibly to reduce the load put on 36.3.
Quote from: MikeSh on Jun 19, 2009, 08:23:32
I don't think it's anything to worry about, Mike.
If you leave the router to automatically get them, then .36. comes up as the primary.
The change is to make the faster server the primary. :)
MikeSh
Quote from: Rik on Jun 19, 2009, 13:25:27
Oh so there is method in their "madness"?
Thanks Rik.
Mike
One server is 'inside' the internal network, so it's a bit faster. The other one is on the 'public' side, so it's there if the network goes down, but it's a tad slower - we are talking a couple of milliseconds only, though.
