Anyone else having problems with NOD updates
Started by Rik, Jul 06, 2009, 17:05:06
None of my machines will update. NOD blame server problems. There's a thread a Wilders supporting this, and suggesting removing and re-installing but many people have ended up worse off.
Anyone else?
No problem here, Rik, mine successfully updated automatically at 15:55. My 2nd MC has just updated when I switched it on as well :)
Thanks, Ray. It's obviously affecting some but not all - perhaps it depends on the server you hit?
I've just manually selected um14.eset.com and got the update...
I wonder if Noreen is having similar trouble?
Wasn't she having trouble a few days ago gettting a Vista service pack to install as well?
A while ago, Ray, can't speak for a few days...
Niall
As I was offline for 3 months on my main PC, I was concerned I'd have problems with everything people were reporting but it all seems okay. I did notice though that the build of NOD I'm using seems to be a slightly older one, but with the latest definitions. I really wish they'd do full testing then allow you to update the program through the program, like all the other programs I use.
And just for good measure - program program program. There, I think I've said program enough in this post :D
Flickr Deviant art
Leo Tolstoy
I've not had any problems with updates either. Thankfully for me, nod has been set and forget!
mrapoc
