dvds
Started by Baz, Jul 13, 2009, 16:06:50
do you know of a program to rip DVDs to computer then maybe convert to Divx format so as to save on a phone.
Free prog if possible.
Sandra might be your best bet, Baz. ;)
ok cheers Rik never thought of that  :thumb:
Answered, but not yet by Sandra.  ;)
bobleslie
Baz,
Have a look in download.com to see if anything takes your fancy.
That's if you haven't done it already.
=Bob=.
Sky/Easylink LLU. Thankfully! ;-)
thanks will take a look at that.Have you used it Sobranie?
Nope but a friend says it's good.  I tend to do things the other way around with a vso prog.(convert x to dvd).
I've always found this site to be the best for questions like this.
http://www.videohelp.com/convert
RichR
Try Handbrake
I use it to rip DVDs for AppleTV and iPhone. It doesn't do DivX but does do MPEG4 and H.264.
I use Handbrake on my Mac. I hadn't realised it was available for Windows too. :thumb:
And on your MINI?  :whistle:
