hmm have to watch this...
Started by pup, Jul 14, 2009, 15:11:48
pup
seemed a bit sluggish today so did a bt test.
Test1 comprises of Best Effort Test: -provides background information.
    Your DSL connection rate: 8128 kbps(DOWN-STREAM),  448 kbps(UP-STREAM)
    Actual IP throughput achieved during the test was - 1405 kbps
Uptime:   12 days, 6:19:42
Modulation:   G.992.1 Annex A
Bandwidth (Up/Down) [kbps/kbps]:   448 / 8,128
Data Transferred (Sent/Received) [MB/MB]:   172.31 / 954.75
Output Power (Up/Down) [dBm]:   11.5 / 19.5
Line Attenuation (Up/Down) [dB]:   13.0 / 23.5
SN Margin (Up/Down) [dB]:   24.0 / 7.5
Vendor ID (Local/Remote):   TMMB / ALCB
Loss of Framing (Local/Remote):   0 / 0
Loss of Signal (Local/Remote):   0 / 0
Loss of Power (Local/Remote):   0 / 0
Loss of Link (Remote):   0
Error Seconds (Local/Remote):   1,468 / 0
FEC Errors (Up/Down):   0 / 0
CRC Errors (Up/Down):   140 / 1,994
HEC Errors (Up/Down):   24 / 1,466
Pup
Sitting on the fence......
And Laughing at both sides.
Have you seen Tim's announcement, Pup? If not, try re-booting.
pup
i havent, ill have a look now  :thumb:
Pup
