MS update problem
Started by talos, Jul 17, 2009, 11:15:43
talos
After the last batch of auto updates from MS, my comp keeps finding a new update every time I switch it on, it goes through the normal process, download, install Etc but records nothing in the log as failed or otherwise, I think a bug came with the last batch, is anyone having the same or similar happening?
Nothing like that here, Bob. Have you tried doing a manual update?
talos
Yes Rick, same result, I have also switched the auto update off, but the system nag drives me barmy.
Odd.  ??? Do you get any clue what the update is?
talos
Yes     Security Update for Microsoft XML Core Services 4.0 Service pack 2 (KB954430)    Size 5.4mb
There no sign of it in the log :dunno:
talos
Thanks Rik, that fixed it, strange nobody else seems to have had the problem. :dunno:
I seem to be having a few probs today, just lost my connection, rebooted router & comp all seem Ok now :comp: :hairpull:
talos
Kids break up to-day as well :eek4: I can't get onto the main road for caravans :rant2: I think I'll go back to bed :doh:
The joys of a British summer. :)
