High pings again
Started by glen, Jul 20, 2009, 10:34:43
juiceuk
I left the router off for about 5mins and I'm getting this. ???
C:\Documents and Settings\deano>tracert www.idnet.net
over a maximum of 30 hops:
  1     3 ms     3 ms     3 ms  192.168.1.1
  2     *       24 ms    24 ms  telehouse-gw2-lo1.idnet.net [212.69.63.51]
  3    24 ms    23 ms    24 ms  telehouse-gw3-g0-1-400.idnet.net [212.69.63.243]
  4    28 ms   318 ms   316 ms  redbus-gw2-g0-1-331.idnet.net [212.69.63.5]
  5    24 ms    24 ms    24 ms  redbus-gw1-fa2-0-300.idnet.net [212.69.63.225]
  6    24 ms    24 ms    24 ms  www.idnet.net [212.69.36.10]
Trace complete.
I'm sure Simon will appreciate that comment, Tac.
Quote from: juiceuk on Nov 02, 2009, 16:37:34
Trace complete.
Are your pings better? The earlier advice I was giving on IP addresses has clearly not worked as expected.
Quote from: Tacitus on Nov 02, 2009, 16:35:35
I don't know whether to put this in a separate thread, but to have the MD of your ISP ring you, since he had noticed my earlier comment on this forum regarding excessive pings is truly exemplary service.   :)
It's a pity not everyone appreciates the efforts IDNet often go to, so thanks for posting that, Tac.  :thumb:
Its feels alot quicker tonight.
Its tempting to try when I get home but support will have gone home, I think I'll give my router a dose of something beginning v and ending with a. :fingers:
If you have any major problems, Steve, call the out of hours number.
My pings are not fantastic, but then I don't game, so it's not too much of a problem:
Reply from 212.69.36.10: bytes=32 time=32ms TTL=59
Reply from 212.69.36.10: bytes=32 time=30ms TTL=59
Reply from 212.69.36.10: bytes=32 time=31ms TTL=59
   Minimum = 30ms, Maximum = 32ms, Average = 31ms
C:\Documents and Settings\Simon>ping bbc.co.uk
Pinging bbc.co.uk [212.58.224.138] with 32 bytes of data:
Reply from 212.58.224.138: bytes=32 time=30ms TTL=121
Reply from 212.58.224.138: bytes=32 time=32ms TTL=121
Reply from 212.58.224.138: bytes=32 time=31ms TTL=121
Ping statistics for 212.58.224.138:
Quote from: stevethegas on Nov 02, 2009, 16:40:25
You wont need to reboot, you might have a pipe all to yourself  :laugh:
I'm averaging 27ms on WBC.
Quote from: Rik on Nov 02, 2009, 16:42:32
Thats with interleaving on though? If so then thats good.
Mines on fast and averaging 13ms. Interleaving takes mine near the 100ms mark.
Yes, interleaving on, sadly.
Well, I'm happy that it's working.  What's a few milliseconds between friends?  :)
Gaming friends or normal people? ;D :out: :hide:
Quote from: Simon on Nov 02, 2009, 16:45:43
A headshot  ???
;D
Now on the 99 IP, was on the 59 before. Need to give Simon another ring as everything has gone slow again. :(
 1    10 ms    98 ms    99 ms  dsldevice.lan [192.168.1.254]
 2  1504 ms  1924 ms  1871 ms  telehouse-gw4-lo2.idnet.net [212.69.63.99]
 3  2267 ms  2184 ms  2429 ms  telehouse-gw3-g0-1-400.idnet.net [212.69.63.243]
 4  2406 ms  1706 ms  1447 ms  redbus-gw2-g0-1-331.idnet.net [212.69.63.5]
 5  1689 ms  1666 ms  1895 ms  redbus-gw1-fa2-0-300.idnet.net [212.69.63.225]
 6  2219 ms  2254 ms  2240 ms  www.idnet.net [212.69.36.10]
Trace complete.
Quote from: Sebby on Nov 02, 2009, 16:47:44
Trace complete.
You've not connected to Tiscali by any chance?  :eek4:
Aaron
  1     1 ms    <1 ms    <1 ms  192.168.0.1
 2    98 ms    90 ms    89 ms  telehouse-gw2-lo2.idnet.net [212.69.63.55]
 3    79 ms    78 ms    81 ms  telehouse-gw3-g0-1-400.idnet.net [212.69.63.243]
 4    85 ms    99 ms    94 ms  redbus-gw2-g0-1-331.idnet.net [212.69.63.5]
 5    83 ms    79 ms    77 ms  redbus-gw1-fa2-0-300.idnet.net [212.69.63.225]
 6    41 ms    41 ms     *     www.idnet.net [212.69.36.10]
 7    53 ms    55 ms    49 ms  www.idnet.net [212.69.36.10]
This is the old link I think, will reset PPP tomorrow instead as it looks like some are still having ping issues on the new hostlink so will wait for it to settle down.
Btw, how do you reset PPP on a Netgear DG834? I could only find reboot and that will give me too high a sync if done in the day.
juiceuk
It's looking better now Rik.
 2    24 ms    25 ms    24 ms  telehouse-gw2-lo1.idnet.net [212.69.63.51]
 3    24 ms    24 ms    25 ms  telehouse-gw3-g0-1-400.idnet.net [212.69.63.243]
 4    24 ms    24 ms    24 ms  redbus-gw2-g0-1-331.idnet.net [212.69.63.5]
 5    24 ms    24 ms    25 ms  redbus-gw1-fa2-0-300.idnet.net [212.69.63.225]
 6    27 ms    24 ms    24 ms  www.idnet.net [212.69.36.10]
Trace complete.
:D Watch out on the battlefield I'm back! Anyone know why my first hop says 3ms instead of 1ms? Do I have a lazy router? I'm using homeplugs if that would make a difference.
Quote from: Aaron on Nov 02, 2009, 16:53:25
Not necessarily, it seems the IP addresses are not working as expected.
Quote from: juiceuk on Nov 02, 2009, 16:59:53
Homeplugs could well cause that.
Quote from: Rik on Nov 02, 2009, 17:11:02
One thing i noticed Rik..
I got moved from telehouse-gw2-lo2.idnet.net [212.69.63.55] to telehouse-gw2-lo1.idnet.net [212.69.63.51]
So maybe if the 2nd line changes from your old tracert then you've been moved?
It seems it's something like that, Paul.
