Lost internet connection
Started by UncleBob, Sep 10, 2009, 15:03:41
Yes, it's BT that validates the password before putting the connection across to IDNet, Tac. (I think  ;))
UncleBob
Hi all,
Just a quick 'follow-up' post.
I contacted support but unfortunately there is nothing that they can do 'after the event' to identify what the problem may have been.  Their tests showed that everything is fine now and, indeed, everything has been fine ever since my last post.  Weird.
Anyway, thanks again and keep up the good work.
Thanks for the update, Bob. We'll put it down to gremlins, then. ;)
Dangerjunkie
Hi Bob,
Glad to hear you're up and running again. Sounds like he fault-fairy visited in the middle of the night and mended it :)
Hope to see you on the board in future.
All the best,
Paul.
