Windows 7 error
Started by Den, Oct 22, 2009, 10:03:08
Den
Just remember that if you are running Vista Premier you can update to W7 premier without having to reinstall everything but if you move up a level it has to be a clean installation  :o
Mr Music Man.
David
On the machine I have in mind Den it only has Vista basic or home whatever its called
I always re-install, it give the OS a refresh, rather than taking the rubbish that you have accumulated with it to the new OS
David
As its a machine which gets used very seldom I may try that blaster whatever its called....
