Please help...........
Started by ReDGryphoN, Oct 23, 2009, 13:41:27
ReDGryphoN
Hi,
Not moved over to ADSL2+ yet I am told its Monday but off work 1/2 day today and thought my computer net speed was slow but this is the lowest it has ever been.
can anyone please help here?
ReD
KOFACME
BILLION 8800NL USER FTTP
Henry David Thoreau
I can only see the text of your post, Red, but if you've rebooted your router, I can only suggest you contact IDNet.
I can't see anything else Simon
ReDGryphoN
Ite the BT speedtest result
132Kbps (red bar) (max achievable 2000)
It says contact your ISP
So I guess I will have to
Henry David Thoreau
Has your profile dropped, or just the throughput?  Router stats?  Any increase in noise margins?
The profile is okay, but something's not. If rebooting your router doesn't help, you'll need to get onto IDNet.
ReDGryphoN
Have reported it to IDNET
and woe of woes for me as a gamer....
Reply from 212.69.36.10: bytes=32 time=174ms TTL=59
Reply from 212.69.36.10: bytes=32 time=136ms TTL=59
Reply from 212.69.36.10: bytes=32 time=196ms TTL=59
Reply from 212.69.36.10: bytes=32 time=166ms TTL=59
    Minimum = 136ms, Maximum = 196ms, Average = 168ms
Something defintely wrong
ReD
KOFACME
Henry David Thoreau
