want to move off connect to IDNet
Started by Happy Surfer, Oct 23, 2009, 13:55:55
JohnH
Welcome.  :thumb: All being well, you'll have to change your name on this forum.  ;D
That's very true, or at least add 'ex-' to the front of it.  ;D
Happy Surfer
thanks for the welcomes,i cant seem to be able to change my username?
also on the the bt speedtester what do i put in the login section instead of @skydsl?
thanks all  8-)
PM the admin team with what you would like your new username to be, we can then change it.
With regards to the BT speedtest, use the same login details, that you use for your router to connect to IDNet.
Happy Surfer
got my new username :thumb:
on the bt speedtester site tho couldnt manage to do the test,when i done it with sky it was the router mac in the first box then @skydsl in the second,can anyone confirm what is needed for idnet login?
Depends what your IDNet router log in is.  Mine, for example, is IDNet.gw5.
Sorry, by router, I mean account.
Essentially, if your router logs in as user@idnet.gw5, you put user in the first box and idnet.gw5 in the second.
Just operating in triplicate, Glenn. :)
Happy Surfer
just thought id share my new bt speedtester results, one is in the morning at 11:15 and the second is 10 minutes ago  :whistle:
[attachment deleted by admin]
Looking good. You could perhaps do slightly better - it might only need an MTU/RWIN tweak. :)
davej99
Quote from: Rik on Nov 03, 2009, 16:30:08
I carried on as before puting the whole user name in the first (*) box and ignored the second. It seemes to work. Do you think that is wrong Rik?
In theory, but if it works, why argue, Dave? :)
