Evil malware program
Started by Colin Burns, Dec 09, 2009, 18:59:36
Colin Burns
Has anyone come across an alleged anti virus program that calls itself SWP2009 demo  /antivirus live.
It seems to be a clever little thing as there is no trace of it in add/remove programs and unless you kill all the proccesses be ran by yourself you cant even gain access to add remove programs or anything else.
Any information anyone has on this would be greatly helpful.
Malwarebytes is your friend in this case, download it on another machine, then install and run malwarebytes in safe mode, delete the infected files it finds.
Colin Burns
 :thnks: Rik and Glenn will attempt glenns then if fails riks approach tomorrow when i go for round to at the poor computer
I use that method 4 or 5 times a month at work Colin, it's never failed me yet, but there is always a first time.
Colin Burns
my ex foremans dads computer
Make sure you run a full scan.
Colin Burns
D-Dan
Change the name of the Malwarebytes executable to something else, too. Some Malware will detect it by name. Try calling it George. No one ever attacks a George.
Have I lost my way?
I don't know, someone threw a shoe at one.  :)
D-Dan
Damn - I was only thinking about Brits - I forgot about that particular George
Perhaps Cyril would have been a better suggestion
Have I lost my way?
Colin Burns
thanks everyone for the help on this problem and for recommending the program....
it only found 253 files  :eek4:
thanks again Colin
