Next Patch Tuesday
Started by Noreen, Feb 05, 2010, 12:57:02
My WHS is having issues since the updates  :mad: The connector no longer works, I can't repair or reinstall it either. The certificate used to connect via Remote Desktop is now invalid too  :mad:
Not that its any consolation but mine is ok following the updates, I wonder if its anything to do with the X file edition? Is there a Server 2003 repair console like in XP?
wecpcs
Quote from: Steve on Feb 11, 2010, 18:43:46
I have just checked my WHS and it has updated without any issues either.
No problem with mine either.
