looking to possibly join
Started by walker, Mar 11, 2007, 16:49:50
Quote from: Sheltieuk on Mar 12, 2007, 15:13:20
Also had a problem around the same time lost connectivity to DNS server no 1 for some reason although I still had adsl synch and router was telling me I was still connected to the net, couldn't access web sites or download mail though.
Did a disconnect from net and couldn't reconnect for several minutes due to authentication failures, re-entered my username and password into router and reconnected straight away - strange  ???
Very similar to my symptoms, Sheltie, I just used a re-boot to clear the session instead of re-entering my username... Perhaps they've given us the new central to play with between ourselves. :)
MoHux
Quote from: lance.......... Our contract with BT costs a massive £24m -ish a year!
WoW!!  You must all be online nearly as much as Rik!  :P :out:
LOL!
I just can't get the super glue off the keyboard, Mo. I think Sue uses it to keep me quiet. :)
Update from Simon:
Telecity had a power outage this afternoon, at around 13:12.
I'd say it was exactly 13:12 myself. :)
