are o2 blocking pptp?
Started by g7pkf, Apr 23, 2010, 22:00:24
g7pkf
from about the 20th of this months anyone know?
Just i have a relative who pptp's to one of my servers and now they cant!!
Haven't seen anything here, Dean, might be worth looking at ThinkBroadband.
g7pkf
Did a bit of digging turns out they are rolling out a router firmware that blocks vpn.
O2 support's stock answer is we do not support vpn your browsing etc is fine-go away.
I am going to try and convince her to come to the good side :)
O2 seem to have bitten off more than they can chew as an ISP which is a shame as they started off so well, I can see why Orange are giving up, its not good for your overall image.
MisterW
QuoteDid a bit of digging turns out they are rolling out a router firmware that blocks vpn.
PlusNet had that problem recently on their Thomson TG585v7 routers ( I think O2 use the same box ), but have now issued new f/w that puts PPTP support back in.
pdu
Hit your local freecycle, someone will be giving away a router that sucks slightly less than thomson kit tends to, definitely worth switching to a different product if it can stop your ISP screwing your router up whenever they see fit :)
quandam
Quote from: g7pkf on Apr 23, 2010, 22:00:24
Are we talking about the 02 Access package here?
MisterW
QuoteAre we talking about the 02 Access package here?
We're talking about the O2 supplied routers ( TG585v7 ) I think.
quandam
Quote from: MisterW on Apr 24, 2010, 19:56:00
MisterW
The original post did not refer to a router as far as I can see, :dunno: It appeared to be referring to a broadband service offered by O2 :dunno: I was simply asking if the OP was related  to the O2 Access package that has a diabolical record of throttling/blocking etc ;)
MisterW
I was following up on g7kps's post
I don't think its related to any particular O2 package, if its like the PlusNet problem its purely down to the router they supplied and maybe upgraded the f/w thereof.
I can't imagine that any ISP is going to directly block VPN traffic on their network.
