Firefox add-on "sitelauncher"
Started by Ted, May 09, 2010, 17:00:06
Ted
If you have sites you open regularly and want to get at easily and quickly, from the keyboard, try sitelauncher
ctrl + space, brings up the interface then just press the letter you need, or, shift + alt + letter, takes you straight there. Works very well.
Ted
It does, A for Amazon, D for Donald Russell, N for Netters, P for Pals. ;D
JB
Quote from: Ted on May 09, 2010, 17:00:06
If you have sites you open regularly and want to get at easily and quickly, from the keyboardes you straight there. Works very well.
Very useful addition for my netbook with limited display space.
Thanks Ted.  :karmic:
JB
