Anyone with experience of Spyware Doctor?
Started by AvengerUK, Mar 06, 2007, 11:48:45
AvengerUK
Ok, thanks rik ;) - ill leave it on its own for now then!
Note: AMON can interfere with games a little, depending on how much info your game loads. However, it has a "exclude folder/file" option - which is simply great!
I'll have to take your word on that Avenger. The nearest I come to a game is playing Solitaire when I'm really bored. :)
AvengerUK
hehe ;) - well, for once the "fan boys" of something are "fan boys" for a good reason ;)
mrapoc
That reminds me, time to reinstall 2142 aka, Glitchmaster 3000
AvengerUK
AvengerUK
Just one thing to add, that ive noticed since installtion of NOD32 - On shutdown, the FDD is accessed 3 times. Not a problem, just a observation ;)
You have a FDD? :)
AMON > Setup > uncheck diskette.
AvengerUK
Thanks rik :)
You never know...that FDD could be quite usefull at times :)
(actually, it gathers dust! - Only used it to load "boot it ng"!)
I know what you mean, just once in a while something comes along, usually at boot time, that demands a floppy. However, I usually find that, by the time I need one, it has gathered so much dust as to be unusable (diskettes are getting quite hard to find too!), so I keep a USB floppy drive in the cupboard.
AvengerUK
#34
Unticking diskette doesnt do it rik, however unticking either "check on shutdown" or unticking the other box under deskette does it!
Should also note that ive decided i mayaswell go ahead and buy it :) - it doesnt take long to impress me ;)
Glad to hear it, Avenger - you took about as long to decide as I did. :)
AvengerUK
Just a quick question...
Now that spyware doctor 5 has been fully released, should i install that aswell?
I mean, Eset's threat engine also handles spyware etc apparently...not sure if that matters or not in use with a diff spyware scanner?
I didn't stick long with SD, Avenger, as I found a few problems with it. I now use Webroot's SpySweeper, and run that once a week or so, I don't have it running in the background, NOD gets most things, I just let Sweeper try and find anything that's left, which it very rarely does.
AvengerUK
Ok rik - ill have to dig out those instructions someone gave me on how to turn SD's background processes off..(in the forum here somewhere)!
AvengerUK
rgt247
Hi
I have upgraded to v5 now 5.0.0.169 the quick scan ran in 5 mins. Seems ok so far will keep you updated if I have any problems........
Rich
Plusnet :P
AvengerUK
Installed it :)
Seems to be ok now, but at first my Inet went (computer couldnt load any pages etc) then a NOD32 service crashed, then Firefox crashed...then IMON said "Repaired settings something or other" - and now working again :S.
Might of been because Firewall was stopping SD update (blocking) and i clicked cancel by mistake on NOD's update...
...Just hope it wasnt anything nasty / caused anything nasty!
It sounds like the experience I had with SD. It's why it's an ex-program on my machine. I hope yours is OK though.
AvengerUK
I think it must of been my firewall..true SD shouldnt of failed if my firewall blocked it...but, then again...most software does ;)
Active gaurd settings are off, which is a good start :)
I just hope the settings IMON said it had changed/restored didnt mess anything up, not to mention NOD crashing in a update!
If you're concerned about NOD, Avenger, go here and test it with EICAR.
