Can some check...
Started by AvengerUK, Mar 24, 2007, 17:53:42
AvengerUK
http://forums.station.sony.com/ps/posts/list.m?topic_id=88000007995
This post ^^
Im not sure wether ive posted anything that will comprimise security...ive checked and it seems ok..but thought id get a second opinion off someone that has nothing better to do  :o  ;) - (joke)
Thanks for whoever checks though...im usually the sort of person who misses the important part!
Well I had a quick look and couldn't see your IP address anywhere so you should be fine! Even with that, you would be fine as long as you have a decent firewall and antivirus software.
I can't see anything really risky, Avenger. I might have removed the machine name, but that's about all.
