Slow Speeds
Started by pakurbagsuk, May 28, 2010, 20:08:26
Sorry to see your problems are worse than I was hoping for. :P
Hope you get it sorted. As Rik said. A spare router would help to see if the lightning fried the other one. I have a spare at the moment. It's a Belkin G mimo if you want to borrow... I think it works.  :whistle:
pakurbagsuk
current status
No other neighbours havin probs
I dont have a backup router to test out
I have effectively unplugged Sky boxes from lines as per suggestion - still no change - but u said this may take a few days.
Its getting really frustrating, especially if i am still going to have to wait till tuesday....
Are you still using the test socket? Can you post another set of router stats from the test socket and also a BT speedtest. Did you manage to get routerstats working its here if didn't find it http://www.vwlowen.co.uk/internet/files.htm
Whereabouts are you, Bags?
Kinellar Aberdeenshire
Of course.  :slap:
I was just thinking if he was in range I could lend him a router.
Well you could drop one off if he's not in a curry sorry hurry. ;D
 ;D
Yup, delivery June 26...
pakurbagsuk
ok i have installed router starts lite ...what would u like me to do with it now guys?
pakurbagsuk
new BT speed test results
Download  Speed
426 Kbps
0 Kbps 500 Kbps
Max Achievable Speed
Download speedachieved during the test was - 426 Kbps
For your connection, the acceptable range of speeds is 100-500 Kbps.
Additional Information:
Your DSL Connection Rate :7104 Kbps(DOWN-STREAM), 832 Kbps(UP-STREAM)
IP Profile for your line is - 500 Kbps
pakurbagsuk
Think this is what u were looking for?
[attachment deleted by admin]
The Noise Margin graph is pretty stable so it could well be that the profile will improve over the next few days.
SNR should be much lower @ 6 - 8db , it is t 15db now with interleaving turned on which means the system was affected by a lot of noise/interference for some reason.
If the line stays stable for a while support can ask BT to drop the SNR for you.  Keep the router on and record with router stats as long as possible as this will show any spikes if they happen.
I can't add to what Dorset has said. Your line looks find now, but something fairly catastrophic in terms or noise or repeated resyncs has forced your profile, and with it your throughput, low. All you can do at this point is to wait for it to recover. If it hasn't by Tuesday, support can get BT to give it a  nudge.
