Mail alerts form my router.
Started by BAP, Jun 11, 2010, 07:55:42
BAP
Hi
First post, hope someone can help.
Sending mail alerts form my router (Vigor 2710Vn) and I get this message.
The SMTP Server is error. I am using SMTP.idnet.net.
I am with ID net SMTP.idnet.net works OK with outlook 2007.
 :welc: :karma: BAP
I dont know whether the space between id & net is deliberate or a typo but suggest try smtp.idnet.com
Suggested settings from IDNet website
@idnet.com Incoming server: pop3.idnet.com Outgoing server: smtp.idnet.com
@idnetfreemail.co.uk Incoming server: pop3.idnet.net Outgoing server: smtp.idnet.net
@idnet.co.uk Incoming server: pop3.idnet.net Outgoing Server: smtp.idnet.net
Authentication is set to none
BAP
Hi BAP, welcome to the forum. Try using mail.idnet.com, see if that works. :welc: :karma:
BAP
#6
Quote from: Rik on Jun 11, 2010, 10:24:46
I gave mail.idnet.com and net a go, no luck. the mail server has to be an IP address, I think, might have to ping  idnet's SMTP server and use that address for the SMTP setting.
Try using smtp.idnet.com for sending emails, this is the one I'm using as my smtp server for Idnet emails.
Hi BAP
Support recommend using smtp.idnet.com, as Ray says. If you're still having problems, they can check the server logs against your IP address and see what's going on.
