Broadband usage stats not working?
Started by Pix, Apr 03, 2007, 13:56:34
Pix
Since the start of April my usage stats seem to have stopped working. They showed me using over 3gb on the 1st when i downloaded around 1gb, and yesterday show me using nothing when i must have used about 4-5gb. Is anyone else having problems or is it just me?
Mine seem OK. However, there is often a distortion in the prediction at the beginning of the month. If you're concerned, I would suggest giving support a call.
Welcome to the forum, Pix.
Mine seems ok. Sometimes a disconnect and reconnect can help sort it out. Failing that, just give CS a ring and they should be able to have a look/sort it for you.
