Firefox problem
Started by Ray, Sep 03, 2010, 12:17:04
Whenever I try to load this Sky page using FF the browser freezes and I have to terminate it via Task Manager, anyone else have the same problem? works fine in IE8
Fine here, Ray. Add-on problem?
Doesn't seem to be, Rik, I've tried with them all disabled and cleared the cache, still freezes.  ???
No problem from my lads machine.
no probs here.what version of FF you using Ray.
I have noticed lately that on odd occasions with FF I get slow loading pages,your link did, and the page hangs for a while.I stop the load and a refresh seems to get it back to normal.Haven't found what it is yet though  :dunno:
You need a decent router, Baz. ;D :out:
I'm using version 3.6.8 which is the most recent as far as I know, Baz.
Well I've just tried the page in FF on my other machine and it works fine, I use the Febe addin to back up my FF profiles so I've just restored a profile from a couple of days ago onto my main MC, the page now works fine.
So it would seem my FF profile on this machine was corrupted and causing the problem. :phew:
I've noticed this fault too, would report it to Mozilla but can't pin it down.
