drops
Started by Baz, Sep 19, 2010, 07:13:57
any one have a drop at about 2.00am on friday morning or was it just me.was only for about 2 minutes
No problem here, Baz.
Nothing here, Baz - sync or PPP?
I was asleep.  :)
Quote from: Rik on Sep 19, 2010, 11:38:42
sorry Rik I can never remember how to tell no matter how many times you tell me  ;D ;D  :blush:
router logs show
Fri, 2010-09-17 02:01:56 - LCP down.
Fri, 2010-09-17 02:02:03 - Initialize LCP.
Fri, 2010-09-17 02:02:03 - LCP is allowed to come up.
Fri, 2010-09-17 02:03:03 - Initialize LCP.
Fri, 2010-09-17 02:03:03 - LCP is allowed to come up.
Fri, 2010-09-17 02:04:03 - Initialize LCP.
Fri, 2010-09-17 02:04:03 - LCP is allowed to come up.
Fri, 2010-09-17 02:05:03 - Initialize LCP.
Fri, 2010-09-17 02:05:03 - LCP is allowed to come up.
Fri, 2010-09-17 02:05:38 - CHAP authentication failed
Fri, 2010-09-17 02:05:38 - LCP down.
Fri, 2010-09-17 02:06:03 - Initialize LCP.
Fri, 2010-09-17 02:06:03 - LCP is allowed to come up.
Fri, 2010-09-17 02:06:35 - CHAP authentication failed
Fri, 2010-09-17 02:06:35 - LCP down.
Fri, 2010-09-17 02:07:04 - Initialize LCP.
Fri, 2010-09-17 02:07:04 - LCP is allowed to come up.
Fri, 2010-09-17 02:08:02 - CHAP authentication failed
Fri, 2010-09-17 02:08:02 - LCP down.
Fri, 2010-09-17 02:08:04 - Initialize LCP.
Fri, 2010-09-17 02:08:04 - LCP is allowed to come up.
Fri, 2010-09-17 02:09:04 - Initialize LCP.
Fri, 2010-09-17 02:09:04 - LCP is allowed to come up.
Fri, 2010-09-17 02:10:04 - Initialize LCP.
Fri, 2010-09-17 02:10:04 - LCP is allowed to come up.
Fri, 2010-09-17 02:10:56 - CHAP authentication success
Fri, 2010-09-17 02:49:29 - Initialize LCP.
Fri, 2010-09-17 02:49:29 - LCP is allowed to come up.
Fri, 2010-09-17 02:50:01 - CHAP authentication success
and sorry I havent read that correctly it was in fact  9 mins and then again later for a bit.
That's resyncs, Baz, and at that time of night, I'd say BT were working at your exchange.
ok cheers.any way of finding that out?
Not really, Baz. BT don't tell IDNet if they are doing individual exchange work.
 :thumb:  Rik
seem to be getting a few lately.was just getting a good up time too.Have put off buying a new router as its been a bit better but would be nice to know which side is causing the bother.
Most BT work occurs between midnight and 7, most commonly, and disconnections will happen around 2am. Check when your exchange is going 21CN, the engineering work for that causes interruptions. (Also check whether you have a dial tone and/or any noise on the phone at the time.)
oh dear  here we go again  >:( >:( >:(
Wed, 2010-09-22 02:32:04 - LCP down.
Wed, 2010-09-22 02:32:12 - Initialize LCP.
Wed, 2010-09-22 02:32:12 - LCP is allowed to come up.
Wed, 2010-09-22 02:33:12 - Initialize LCP.
Wed, 2010-09-22 02:33:12 - LCP is allowed to come up.
Wed, 2010-09-22 02:34:12 - Initialize LCP.
Wed, 2010-09-22 02:34:12 - LCP is allowed to come up.
Wed, 2010-09-22 02:35:12 - Initialize LCP.
Wed, 2010-09-22 02:35:12 - LCP is allowed to come up.
Wed, 2010-09-22 02:36:12 - Initialize LCP.
Wed, 2010-09-22 02:36:12 - LCP is allowed to come up.
Wed, 2010-09-22 02:37:12 - Initialize LCP.
Wed, 2010-09-22 02:37:12 - LCP is allowed to come up.
Wed, 2010-09-22 02:38:12 - Initialize LCP.
Wed, 2010-09-22 02:38:12 - LCP is allowed to come up.
Wed, 2010-09-22 02:39:12 - Initialize LCP.
Wed, 2010-09-22 02:39:12 - LCP is allowed to come up.
Wed, 2010-09-22 02:40:12 - Initialize LCP.
Wed, 2010-09-22 02:40:12 - LCP is allowed to come up.
Wed, 2010-09-22 02:41:12 - Initialize LCP.
Wed, 2010-09-22 02:41:12 - LCP is allowed to come up.
Wed, 2010-09-22 02:42:13 - Initialize LCP.
Wed, 2010-09-22 02:42:13 - LCP is allowed to come up.
Wed, 2010-09-22 02:43:13 - Initialize LCP.
Wed, 2010-09-22 02:43:13 - LCP is allowed to come up.
Wed, 2010-09-22 02:44:13 - Initialize LCP.
Wed, 2010-09-22 02:44:13 - LCP is allowed to come up.
Wed, 2010-09-22 02:45:13 - Initialize LCP.
Wed, 2010-09-22 02:45:13 - LCP is allowed to come up.
Wed, 2010-09-22 02:46:13 - Initialize LCP.
Wed, 2010-09-22 02:46:13 - LCP is allowed to come up.
Wed, 2010-09-22 02:47:13 - Initialize LCP.
Wed, 2010-09-22 02:47:13 - LCP is allowed to come up.
Wed, 2010-09-22 02:48:13 - Initialize LCP.
Wed, 2010-09-22 02:48:13 - LCP is allowed to come up.
Wed, 2010-09-22 02:49:13 - Initialize LCP.
Wed, 2010-09-22 02:49:13 - LCP is allowed to come up.
Wed, 2010-09-22 02:50:13 - Initialize LCP.
Wed, 2010-09-22 02:50:13 - LCP is allowed to come up.
Wed, 2010-09-22 02:51:13 - Initialize LCP.
Wed, 2010-09-22 02:51:13 - LCP is allowed to come up.
Wed, 2010-09-22 02:52:13 - Initialize LCP.
Wed, 2010-09-22 02:52:14 - LCP is allowed to come up.
Wed, 2010-09-22 02:52:19 - CHAP authentication success
hope its not going to be regular whatever it is.
Ask support if they have any notification from BT of work being done at your exchange, Baz. It might be a good idea to also run the router from the test socket and see if it helps.
I'm never around at that time to notice I wouldn't worry unless your sync is being affected, BT work probably. Mind you I've lost interest in log checking, as longs as it's working and throughput is ok I'm really not bothered what happened during the night.
I know just what you mean, Steve.
I know what you mean too Steve but Ive had a few recently and cant find out what the problem is.Was thinking of getting a new router but then it settled down after the recent work that was done,IDnet or BT cant remember, but ive had two in a week
will drop them an email Rik    :thumb:
if I knew the address   :whistle:   :D
Loss of sync is always an issue between your router and the exchange, Baz. It is never anything to do with an ISP.
I was just saying that it improved whatever the work was and I couldnt remember who did the work  :)
I found the email address too  :thumb:
