Rebooting 2-wire v6
Started by tehidyman, Oct 16, 2010, 21:51:07
tehidyman
After a bad dose of noise on line my 2-wire has now settled to a steady 6db margin and the sync is 3936kbps. I thought it was worth a try to get it to resync at over 4000kbps to get the next level of IP Profile (which I had before the problems). Should I use the reset broadband button or the reset system button.  I am on downgraded ADSL2+ and Firmware Version: 6.1.1.48.1-enh.tm
The reset broadband button will do what you require.
tehidyman
Thanks for that. Sync rate now 4192kbps,  so now wait a few days  :fingers:
