Line Bonding?
Started by netgem21, Oct 16, 2010, 21:15:00
netgem21
Does IDNet support ADSLMax Line Bonding?
Thanks  ;D
I've absolutely no idea. It wouldn't surprise me if they do but I expect the quickest way to get an answer will be to give support a ring on Monday.
I doubt any BTW reseller supports Line Bonding.
Be do however - https://www.bethere.co.uk/web/beportal/linebonding
As Griff says the only one I can think of is Cerberus networks, never used them so don't know what they are like.
Cerberus Networks use the Be/O2 network hence they're able to provide Line Bonding as well.
You can just imagine line bonding with BT, one line with an IP profile of 135 and the other at 5500. >:D
Quote from: .Griff. on Oct 16, 2010, 22:31:09
Apologies didn't know that.
Quote from: pctech on Oct 16, 2010, 22:47:22
No problem mate. I didn't mean to sound "know it all" if that's how it came across.
no you didn't come across like that at all.
Xilo have "Bonded ADSL" coming soon on their site ........ how soon or what it entails is anyones guess.
I think they use BE/O2 too Dorset, I did look at them.
Quote from: pctech on Oct 17, 2010, 13:39:27
Don't think they use BE/02 at all but could be wrong.
http://www.pro-net.co.uk/connectivity/bonded-adsl.php is just one company offering bonding, there are plenty if you Google them, reading that you can use any ISP with the bonding service, whatever it is going to add up to a fair monthly bill.
You can always balance 2 ISP's through a router to get redundancy.
JohnH
Just to correct myself they use C&W and Talk Talk LLU.
It's an old article but I found it an interesting read nevertheless http://www.automatedhome.co.uk/Internet/ADSL-Bonding-How-To-and-Review.html
Quote from: JohnH on Oct 17, 2010, 22:03:49
I think AAISP do.
http://aaisp.net.uk/kb-broadband-bonding.html
They're another ISP that uses the Be network. (For some services, line bonding being one of them)
