Printer stopped working
Started by Den, Dec 13, 2010, 12:20:31
Den
Thanks Rik, just done that and it works  ;D I wonder why it happened?
Mr Music Man.
That's Windows 7 for you, Den. ;D :out:
Den
You need to move with the times Rik  ;)
Mr Music Man.
I'm doing it, Den, and finding I've got obsolete printers because there's no Win 7 drivers for them. :(
Laserjet 1022n, Glenn. The only driver I can find on the HP site is for a USB connection, not a network one. The lappy can see the printer if I log into the EWS via Firefox, but even the original drivers won't co-operate.
Thanks, Glenn, but I can't find a driver on the HP site that isn't for a USB only installation, there seems no network support after XP.
The HP troubleshooting guide is at:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00312056&tmp_task=solveCategory&lc=en&dlc=en&cc=uk&os=228&product=439323&sw_lang=
and I've been right through that.
Where did you get the clue that's a network driver, Glenn, I looked at it before and couldn't see any reference to network printing?
It's the driver Ericsson used at MBNL in Amersham to get the network printers working on a temp basis
How about installing the USB driver for the printer and then adding a TCP/IP port?
Quote from: Glenn on Dec 16, 2010, 18:52:01
Thanks. Are they still using it or did they find a permanent solution?
Quote from: pctech on Dec 16, 2010, 18:53:17
Interesting bit of lateral thinking, Mitch, I may try that if Glenn's method fails...
I've never tried it but as the driver's role is to generate the op codes it should be possible to get it to hand them off to the TCP/IP stack.
 :fingers:
Makes you wonder why HP didn't do it, though, doesn't it.
