Application not found !
Started by David, Mar 05, 2011, 10:38:06
David
This is what I get when I click on a link,I can answer Emails ok ..... has anyone tampered with my bits whilst I have been away ? any idea how one resolves this issue or indeed one like it ?
David
Here and in fact every link Ihave reived the notification from the site when I go to click on the link I just jet a red cross with no application found.its the same with all sites I tried it with another site same so it has to be me .Now last night I uninstalled Chrome obviously this has a bearing on this wondering if I can undo the action ?
Just clicked on the start menu for "Getting Started " in my help window and the same with the microsoft links from the pc menu
So what browser are you using, David?
David
I am now on IE nothing else on here this is the new machine
J!ll
Let me get this clear. When you click on a link, you get an 'application not found' error? The only change you have made is to remove Chrome? Is IE set as your default browser?
David
Yes thats all I did I have done nothing else at all
David
Forcing IE to make itself default may fix the issue.
If it doesn't ask when you start it go to Tools > Internet Options > Programs tab and click Make Default.
If that does not work let me know and I'll have a look on a Windows 7 machine when am at work later unless Dorset beats me to it of course!
David
Yippee thank you  :thumb: Im assuming (dont laugh now) that it was because I had been typing in the browser bar ! dont ask me my logic  ;D
I didn't think you went in for the stuff, David. ;D
David
#12
 :rofl: :rofl3: I just dont care anymore  ;D I have taken the childrens look at this and just do it ....fear is a wonerful thing  ;D :bow:  :thanks3:
J!ll
David
J!ll
TomSG
Had a similar problem with... I forget what it was now. Something really obscure like emails. But windows was all "set the default" "choose the one you want" but would not do anything.  :dunno:
