oh!
Started by Tina, Mar 12, 2011, 21:21:50
Tina
Just has a kernal panic  on my Macbook :( Reset the RAM  and hope it's OK. I can't afford another computer and rely on it so much with not been able to go out alone :(
Quote from: Tina on Mar 12, 2011, 21:21:50
Run permissions check reset pram and maybe start up in safe mode as that empties out a bunch of caches, post on the Apple warzone forum to get help if you can post the kernal panic for help.
Tina
Thanks Gary :) I did all of those things and everything seems OK.
Quote from: Tina on Mar 18, 2011, 21:53:08
Forgot to mention verify you drive as well, just to be safe.
Tina
thanks, I did that while I was doing permissions and it was all OK:)
Quote from: Tina on Mar 19, 2011, 15:55:26
:thumb:
