IOS 4.3.1 is out
Started by Gary, Mar 25, 2011, 23:10:25
Security and bug fixes.
Thanks Gary  :thumb:
It is also reported that it helps with the battery drain problem people have experienced with 4.3.
Quote from: lozcart on Mar 26, 2011, 18:05:51
Thanks Gary  :thumb:
Mine did not seem to bad but it does appear to be lasting fine on 4.3.1 also closed a pwn2own zero day in Safari, so hopefully the new ALSR added with 4.3  should help protect the OS a bit more.  :fingers:
