dgnd3300 2.1.00.48
Started by Obijon, Feb 21, 2011, 17:16:05
Obijon
 Hi, im a new member/long time lurker  :-\ and just wanted to let every one know that the new .48 firmware is out and <GASP> working... so far anyway! Cheers!
  :welc: :karma:
That's a surprise a Netgear firmware that appears to work.
Thanks for that and welcome to the forum. :welc: :karma:
Obijon
well, Ive done a signal check with a handy wifi sniffer app on my droid 2g and ive got approx. the same signal strength i had under the old .42 firmware. All 3 of my pc's hooked right up plus my phone no problems. (the app is called "wifi analyzer" by farproc, available in the Android market if youre interested...)
wecpcs
Quote from: Obijon on Feb 21, 2011, 17:16:05
But it does totally ignore IP address reservations as if they were not even there. Netgear are aware of it and are working on a fix apparantly.
Now there's a surprise.  ;)
