Check BT Exchange Faults
Started by cavillas, Oct 30, 2010, 17:44:52
Quote from: Tacitus on Jan 22, 2011, 17:58:05
Thanks for the info on bonding - I just assumed it's something that iDNet would do.  Not that I want to pay £50/month for the privilege  ;D
Probably could do if there was sufficient demand.
I reckon when Fibre to the premises becomes more widespread it will of course negate the need for bonding.
It will, Mitch, I see banding as very much a 20CN product.
When fibre does become ubiquitous it'll be interesting to the see the effects on ISP's prices as in theory their costs should come down as it lower maintenance.
Though that depends on BT...
With a customer base larger than Virgin, BT's BB/phone package prices should undercut Virgin for a similar product.
You'd have thought so wouldn't you and that fibre would have been rolled out years ago.
To summarise, it would be a great help if you told us which part of the country you are in. Someone losing their service in NE Scotland is likely to have a different problem to someone in Cornwall, and unless we know where you are, we can't look for BT issue reports.
It doesn't have to be too specific, though if you live in a large town, it will obviously be more helpful to indicate which part of the town than to just name the town. Best of all, if you can identify your exchange for us, we have more chance of finding information to help you.
Thanks.
