Frequent disconnects
Started by Slyder, May 16, 2007, 11:49:05
Well, the finger is definitely beginning to point! ;)
ReDGryphoN
Yes I think it has !
All you have to do now is find a router that suits you and as I had discovered everyone has an opinion !!
ReD
MAABOF
BILLION 8800NL USER FTTP
Henry David Thoreau
Quote from: ReDGryphoN on May 18, 2007, 09:02:43
Life was easier before Max, it was pretty simple to recommend routers. I tend to feel they should now be available on trial, so we could see how they run with a particular line. :(
ReDGryphoN
I totally agree,
There appears to be no "best option" especially if like me you are on a long line with high attentuation.
I was lucky to be able to try 2 and mistakenly buy another type (only to sell it on again) before I got to the one I have. To many chipsets, software GUI's, firmwares, etc etc
Best bet is to see if you can borrow one from someone you know
ReD
JSAWBSAW
Henry David Thoreau
Quote from: ReDGryphoN on May 18, 2007, 09:22:14
I have 56db attenuation. Before Max, I was recommended to use a Draytel 2600+, which was totally reliable. However, once I Max'd, it just didn't hold the line. I ended up with the humble Netgear DG834, which holds down to about -3db noise margin.
QuoteI was lucky to be able to try 2 and mistakenly buy another type (only to sell it on again) before I got to the one I have. To many chipsets, software GUI's, firmwares, etc etc
Too many indeed. Perhaps we ought to think about forming a pool of members who have a range of routers and would be prepared to visit others, or lend the router to others, to check on a given line? There are obviously practical problems in administering such a scheme, but it could be of real benefit.
ReDGryphoN
Lol Rik,
My attenuation is 62dB and the BT checker says I could get 512K !!, I however get 2Meg through mainly my own efforts and now (through IDNET) a stable connection too, I get this with a Noise Margin of 9db so I could tweak some more if necessary but would struggle to get to the next BRAS profile for 2.5Meg.
I had a Netgear like yours but the PN model with the flashing lights etc, but that router for some reason would gradually bleed my noise margin down to 0 or -3 or whatever and would eventually fall over. I had some great graphs from routerstats with this happening ! No rhyme or reason for it. The guy I sold this too actually had an improvement over his line and synch rate etc so he was well delighted !
D Link did not work very well at all nor a Linksys I tried, eventually a Belkin 7633 (the tweakable version with DMT, there are many 7633's that are not) was my saviour, happy to keep me connected even with a poor line.
ReD
JSAWBSAW
Henry David Thoreau
Quote from: ReDGryphoN on May 18, 2007, 10:51:05
That's not bad for 62db att. I also have a 9db margin to achieve stability (at my request) and usually sync at around 3-3.3kbps, just a bit below the rate for a 3000 profile, so I'm usually on a 2500. With a following wind though... :) It would be nice if BT would use a less coarse stepping sequence for profiles.
QuoteI had a Netgear like yours but the PN model with the flashing lights etc, but that router for some reason would gradually bleed my noise margin down to 0 or -3 or whatever and would eventually fall over. I had some great graphs from routerstats with this happening ! No rhyme or reason for it. The guy I sold this too actually had an improvement over his line and synch rate etc so he was well delighted !
Which just goes to prove that you can't make simple recommendations these days! Netgears do have a reputation of misreporting noise margin  over a period, ie it will tend to drop away by 2-3db.
QuoteD Link did not work very well at all nor a Linksys I tried, eventually a Belkin 7633 (the tweakable version with DMT, there are many 7633's that are not) was my saviour, happy to keep me connected even with a poor line.
And other people curse anything Belkin! ;)
It seems that, since Max, the only rule about routers is that there are no rules. Why don't we have a sigh icon when I need one! :laugh:
Slyder
Ah, glad that the problem's been found  :laugh:
Now..the challenge of finding a router suitable *sigh* Sounds way too confusing for me, and recommendations wouldn't help would they? >__<
Call support, explain your problem and see if they could lend you a router - unless you have friends around who could help out...
