Disk Cloning Software
Started by zappaDPJ, Apr 11, 2011, 17:33:56
wecpcs
Quote from: Technical Ben on May 22, 2011, 20:32:00
The worst of all is LG drives. Great tech, but horrid applications for the DVD drives. It has a special firmware in built to the drive! So it installs on any platform, without a CD/DVD in the machine. So windows 7 gets a nasty little Logo popping up and welcoming you to the "better way" to do things.
No thanks, I do it my way! If I want nero, I want to be able to use that instead.
Well I have got an LG Blu-ray writer and I have no problems with it whatsoever with Windows 7 and I do not get any little logo popping up.
