No net. Exchange work?
Started by Technical Ben, May 26, 2011, 18:07:01
On phone, so spellings on thin ice.
Seem to be connected to the exchange. But no ip dns or internet. Was fine. No warnings just red light in internet marker on router. dsl light green and steady.
There's a problem in the Milton Keynes area but I've no idea where you are Ben.
We're used to phone spelling :evil: The Idnet status is showing problems with Manchester node 4.
Holbeach. Just dont send any heavies.
Give support a call, there are there for another 15 mins
Though you may want to try re-booting the router while the phone is ringing. :)
Clear time was 17:08, affected exchanges were:
01204   01229   01244   01253   01254
01257   01270   01274   01283   01352
01407   01422   01484   015120   015122
015128   015129   015142   015149   015151
015164   015172   01539   01565   016123
016128   016129   016130   016135   0 16136
016137   016164   016165   016167   016181
016183   016188   016190   016192   016194
016198   01663   01690   01697   01704
01706   01758   01766   01772   01829
01928   01938   01942   01943   01978
01995   01943
Holbeach is 01406, so shouldn't be affected.
Come back, Ben, all is forgiven. ;D
There was WBMC work last night in London which affected MK.
Wasn't using the connection at the time but noticed the uptime had gone back to 10 hours and logs showed LCP initialisation and authentication so assume it must have lost PPP.
Maybe they forgot to press save. ;D
BT don't have a save button, just a delete one. :)
Back now. No idea what it was. Seemed to have sync, but no target margin etc to see on router stats
There is an estate going up, but I would have thought they would not unplug the whole place, to get the new cables in.
So stale session maybe? It just died, half way through browsing.
[edit]
Went down around 17:30. Logs show back up at 19:39.  :o
Was down for 2 hours!?
Quote from: Technical Ben on May 26, 2011, 21:35:08
Could be a case of "JCB, meet buried cable"?
Wouldn't be the first time, and a couple of hours sounds a possible repair time.
sparkler
im in mid wales and i lost internet for a while
Sat, 2000-01-01 00:00:33 - Initialize LCP.
Sat, 2000-01-01 00:00:33 - LCP is allowed to come up.
Sat, 2000-01-01 00:00:43 - CHAP authentication failed
Sat, 2000-01-01 00:00:43 - LCP down.
Sat, 2000-01-01 00:01:05 - Administrator login successful - IP:192.168.0.3
Sat, 2000-01-01 00:01:26 - Initialize LCP.
Sat, 2000-01-01 00:01:26 - LCP is allowed to come up.
Sat, 2000-01-01 00:01:51 - CHAP authentication failed
Sat, 2000-01-01 00:01:51 - LCP down.
Sat, 2000-01-01 00:02:26 - Initialize LCP.
Sat, 2000-01-01 00:02:26 - LCP is allowed to come up.
Sat, 2000-01-01 00:03:17 - CHAP authentication failed
Sat, 2000-01-01 00:03:17 - LCP down.
Sat, 2000-01-01 00:03:26 - Initialize LCP.
Sat, 2000-01-01 00:03:26 - LCP is allowed to come up.
Sat, 2000-01-01 00:04:26 - Initialize LCP.
Sat, 2000-01-01 00:04:26 - LCP is allowed to come up.
Sat, 2000-01-01 00:05:26 - Initialize LCP.
Sat, 2000-01-01 00:05:26 - LCP is allowed to come up.
Sat, 2000-01-01 00:05:59 - CHAP authentication success
sof2er
Same, lost internet for 6-10 mins~
Quote from: sparkler on May 27, 2011, 02:33:10
That looks like the millennium bug to me    :evil:
Mine lost PPP around 0230 needed a kick to re connect just now, I did change the router firmware yesterday.  :dunno:
Update:
Going though town today, I noticed 2 BT openreach vans, and a big hole or two in the pavement. So, I guess they started work around 5:30 yesterday?  :slap:
Strange that they had adverts for fibre optic internet on the building they were fitting the connections too. Does this mean that the office is getting fibre or that they just advertise it, even when they are installing ASDL. ;)
It's a bit like a Sky van, Ben. ;)
Id do wish they would stop marketing it as Fibre optic broadband along with Virgin for that matter.
As far as I understand it the core links of BTs network have been fibre for a while.
When they are installing FTTP then they can call it fibre optic broadband.
It's hyperbole creep. You do know they got legal right to call unlimited plans, with limits, "unlimited" in Australia?
Technicallly there can never be an unlimited plan, as no matter what the bearer technology is, DSL, Copper Ethernet, Fibre or Radio there is always a limit and that's the first thing they teach on a networking course, that use has to be managed.
I think the emphasis is that they put an artificial limit on an "unlimited" plan. Why not call it a "20GB plan" if it's capped to 20GB?  :dunno:
I'd agree with you Ben but the marketing wonks would argue that for most it is unlimited but they may only do the odd bit of browsing.
