Just bought a Blackberry
Started by David, Mar 30, 2011, 14:58:11
Quote from: Glenn on Apr 02, 2011, 17:02:47
0113 234 5678 is the First Direct banking number
Cheers, sounds familiar as they are in Leeds, think I found it a while back but forgot to store it.
How you getting on with your Crackberry Blackberry David?
Mine is due to arrive sometime today.
Have decided to sell my Blackberry because I really don't need the e-mail feature and have learnt what I needed to know about it.
Back on my 6700 now.
What do you prefer about the 6700, Mitch?
slightlky slimmer and prefer the straightforward keypad.
In addition as I sit in front of a PC all day at work and have one at home I don't really have a need to have access to e-mails as soon as they arrive so don't really need to spend a fiver per month on the bolt on.
I empathise with the latter point, mobile broadband really would be wasted on me for the vast majority of the year.
Coupled with the fact dongles are generally c*ap anyway.
;D
They're good enough for the few times I use them. :)
