Windows 7 Safe Mode
Started by Den, Sep 25, 2011, 10:21:33
Den
Twice in the last week my desktop has started in safe mode and I have had to reboot it. Any thoughts as the only thing I have changed is uninstalling Norton 360 and installing Avira?   :dunno:
Mr Music Man.
Do you receive any other errors when the boot process has completed?
Might be worth calling up msconfig (quick way is Windows key and R then type msconfig) and just check Normal startup is selected.
Den
No errors were showing but Normal start up was not ticked, most likely changed by Norton. It's now ticked so I will see if it happens again.   ;D
Mr Music Man.
Fingers crossed it won't
