BlackGold High Definition PCI-e Card, Dual DVB-T/T2, Dual Digital DVB-C
Started by sobranie, Nov 16, 2011, 21:34:50
Anyone using subject item please? Views, positive or negative greatly appreciated.
Never used it. But my experience with TV turners on PCs is mixed. They either work wonderfully, or not a all (IE software/hardware conflicts prevent use).
So check out the forums (for common errors/hardware faults) of the maker, and check out reviews.
Reviews (here and there) are of the opinion that it's brilliant.  I don't really trust reviews in that the manufacturer is quite capable of generating his own reviews, hence I'm trying to find an owner who would give me an unbiased opinion.
Apparently it's supposed to work well with Windows media centre but the only time I've tried this prog resulted in zilch thro. headphones so I presented the prog with the grand order of the boot.
