What is happening
Started by Den, Nov 30, 2011, 16:00:52
Den
I always got a speed of about 6.3mb and a ping of about 35.
http://www.speedtest.net/result/1621483947.png
As far as I know nothing has changed but these days it's just not as good.
Mr Music Man.
What does a BT test reveal?
Interleaved ?  Router stats may tell you.
Den
Yes interleaved is on. These are my stats
Current DSL Connection:
Down
Up
Rate:
7104 kbs
448 kbs
Max Rate:
6148 kbs
988 kbs
Noise Margin:
6.0 dB
23.0 dB
Attenuation:
41.8 dB
26.0 dB
Output Power:
19.7 dBm
11.9 dBm
Mr Music Man.
How are you performing the speedtest? Wired or wireless?
The kids have been off today so the exchanges are probably busy. A BT speed test would give us the profile , the router stats look fine.
Den
Quote from: .Griff. on Nov 30, 2011, 19:03:45
Wired, it's not just today it's been for a while but I just put up with it. I will most likely get up early one morning and reboot the router and see if it syncs at a higher speed. Why do you think the ping has gone up so much?
Mr Music Man.
I think I'd need to see a ping to  www.idnet.net to get a valid comparison as speedtest.net can be variable depending on how busy the server is. Interleave probably adds 10-15mSec.
I don't suppose you setup a TBBQM at any point? http://www.idnetters.co.uk/forums/index.php/topic,27354.0.html
That would indicate if the increase in latency was sudden, gradual or is congestion.
